[Qgis-developer] dev stats
Alex Mandel
tech_dev at wildintellect.com
Fri Feb 3 13:09:27 EST 2012
On 02/02/2012 11:23 PM, Nathan Woodrow wrote:
> I was going to get a csv dump out redmine and generate something like this
> at one stage (a simple version anyway).
> The current problem is the the redmine export limit is too low so you can't
> export all the issue out, only get about 500 when there a lot more.
> There is a limit variable that you can increase, can we get that increased
> to allow a bigger dump out?
> Regards,
> Nathan
> On Fri, Feb 3, 2012 at 5:01 PM, Paolo Cavallini <cavallini at faunalia.it>wrote:
>> Quite interesting:
>> http://blog.**documentfoundation.org/2012/**02/02/fosdem-preview/<http://blog.documentfoundation.org/2012/02/02/fosdem-preview/>
>> In ohloh we have something similar (but unfortunately we lost our history
>> during the passage from svn to git), so would someone volunteer to set up a
>> similar set of plots?
>> All the best.
>> Paolo Cavallini
>> See: http://www.faunalia.it/pc
Give me a hint as to where in the redmine code that might be and I can
do that for you.
Thanks,
Alex
