[Qgis-developer] Small Issue with SVG symbol choice in Print
Composer
Andreas Neumann
a.neumann at carto.net
Mon Feb 6 07:08:05 EST 2012
I just discovered that the SVG symbol choice in print composer - the
list with symbols that is shown after you place an image with the "Add
Image" button scrolls both vertically and horizontally. This is
suboptimal. I think it would be better if the symbol list scrolls only
vertically and the images are re-aligned when the width of the parent
widget changes. This has nothing to do with Nathans redesign, the
behavior was the same before.
In the "Symbol properties" dialogue of the symbolization settings, the
behavior seems like I expect it. Symbols are realigned and there is only
a vertical scrollbar.
How hard would it be to make the symbol choice in print composer behave
like the symbol properties of the symbolization?
Andreas
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
