[Qgis-developer] Composer redesign
James Stott James.Stott at npaconsult.co.uk
Mon Feb 6 08:48:16 EST 2012
Nathan that would be really good if you could take a look at whether multi line item labels are possible.
That does do it for 2 but it then reverts back to what it was originally if you update the layer in the legend doesn’t it or have I missed something?
I want to be able to update all legend items in one go and not have to tweak the legend text each time. Clients can be very good at changing the styles a lot (even when a map is pretty much finished) and if I update then I have to change the text again in the legend. It's very easy to forget to make the legend as it was before you updated it to reflect the style change.
Andreas, I use the following workaround for the 'Legend' Title text issue.
1) Place a rectangle on your composer as the boundary of your legend area.
2) Place a legend within the rectangle
3) For the legend, delete the text 'Legend'
4) On General Options for the legend, set it to have no frame and make it completely opaque (slide the opacity slider right to the left).
5) Then realign your legend on the composer so that the top item in the legend is just below the frame of the rectangle.
This will then make it look like there isn't a gap at the top of the legend.
James
James Stott BSc (Hons) MSc | Senior Professional
Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
T: 01225 445548 | M: -
http://www.npaconsult.co.uk/
-----Original Message-----
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: 06 February 2012 13:38
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Composer redesign
> For 2) I normally just delete the text in the Legend Items tab for
> each item I don't want to show including layer names or group names.
>  Does this do what you need? or have I missed something.
 At least with the "Title" you also have to set the font to something
 really small (1pt), otherwise you would still get an empty row at the
 top of the legend. This is obvious if you also use a frame around the
 legend. Event with setting the font-very small you would still get more
 margin on top of the legend than on the bottom or the sides.
 For the groups or layernames - yes, you can delete them manually. But
 it would be more handy if one could suppress all of them with a
 checkbox. Whereas for groups and layers there is a manual workaround,
 for the "Title" there is no satisfying workaround in my opinion.
 Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
http://www.npaconsult.co.uk/terms.asp
This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website: http://www.npaconsult.co.uk/
