[Qgis-developer] Composer redesign
Nathan Woodrow
madmanwoo at gmail.com
Mon Feb 6 09:10:02 EST 2012
Jamas and Andreas,
I see what you mean. It is a bit of a pain, not very ideal.
I'll see what I can do to improve this. Can't promise anything yes but I'll
have look anyway.
I suspect a redesign of the legend widget to allow more finer control of
each item is in order. One thing I have thought of is control what gets
updated when you click update e.g. only update style; only update text;
update style and text. Things like that.
- Nathan
On Mon, Feb 6, 2012 at 11:48 PM, James Stott
<James.Stott at npaconsult.co.uk>wrote:
> Nathan that would be really good if you could take a look at whether multi
> line item labels are possible.
> That does do it for 2 but it then reverts back to what it was originally
> if you update the layer in the legend doesn’t it or have I missed something?
> I want to be able to update all legend items in one go and not have to
> tweak the legend text each time. Clients can be very good at changing the
> styles a lot (even when a map is pretty much finished) and if I update then
> I have to change the text again in the legend. It's very easy to forget to
> make the legend as it was before you updated it to reflect the style change.
> Andreas, I use the following workaround for the 'Legend' Title text issue.
> 1) Place a rectangle on your composer as the boundary of your legend area.
> 2) Place a legend within the rectangle
> 3) For the legend, delete the text 'Legend'
> 4) On General Options for the legend, set it to have no frame and make it
> completely opaque (slide the opacity slider right to the left).
> 5) Then realign your legend on the composer so that the top item in the
> legend is just below the frame of the rectangle.
> This will then make it look like there isn't a gap at the top of the
> legend.
> James
> James Stott BSc (Hons) MSc | Senior Professional
> Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
> T: 01225 445548 | M: -
> http://www.npaconsult.co.uk/
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org [mailto:
> qgis-developer-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
> Sent: 06 February 2012 13:38
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Composer redesign
> > For 2) I normally just delete the text in the Legend Items tab for
> > each item I don't want to show including layer names or group names.
> > Does this do what you need? or have I missed something.
> At least with the "Title" you also have to set the font to something
> really small (1pt), otherwise you would still get an empty row at the
> top of the legend. This is obvious if you also use a frame around the
> legend. Event with setting the font-very small you would still get more
> margin on top of the legend than on the bottom or the sides.
> For the groups or layernames - yes, you can delete them manually. But
> it would be more handy if one could suppress all of them with a
> checkbox. Whereas for groups and layers there is a manual workaround,
> for the "Title" there is no satisfying workaround in my opinion.
> Andreas
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Qgis-developer mailing list
> http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
> http://www.npaconsult.co.uk/terms.asp
> This Electronic Transmission is intended only for the attention of the
> addressee. It may contain privileged and confidential information. If you
> are not the person for whom it is intended, you must not copy, distribute
> or take any action in reliance on it. If you have received this electronic
> transmission in error please notify us immediately by telephone, delete the
> transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure that
> this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0)
> 01225 445548, Fax: +44 (0) 01225 312387, Website:
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120207/74a15d13/attachment-0001.html
