[Qgis-developer] Windows Installation broken - and cannot uninstall
Giovanni Manghi giovanni.manghi at gmail.com
Wed Feb 8 03:51:00 EST 2012
Use the standalone installer, is less risky to have something get wrong.
About the osgeo4w installer you must not install every package it makes
available, because you can get errors like the one you are seeing (probably
lack of some external library). Stop the services you may have installed (
Apache) and remove the osgeo4w folder, then I usually clean the registry
with ccleaner. Then re-install just what you need, qgis and/or qgis-device.
On Feb 8, 2012 8:39 AM, "Ole Nielsen" <ole.moller.nielsen at gmail.com> wrote:
> Hi QGis developers
> We have just installed QGis on 4 Windows machines in our office to explore
> its potential for sustainable capacity building in an international
> government aid context.
> We installed from the QGIS website the option OSGeo4W Installer because we
> are also doing development.
> However, when attempting to run QGIS we all get the same error:
> *This application has failed to start because ippqj-5.3.dll was not
> found. Re-installing the application may fix this problem.*
> However, we cannot re-install  without first un-installing and have not
> been able to find a method for un-installing the faulty QGIS installation.
> As an aside, we noticed that both QGIS 1.7.3 and QGIS 1.9.90 appear as
> icons.
> Can someone please help us
>    - Uninstall QGIS
>    - Let us know how to install a working version
> This is important for the QGIS project because the lack of good
> installation/uninstallation procedures fuel the perception that Open Source
> projects aren't serious contenders to the traditional commercial products.
> Many thanks for you help
> Ole Nielsen
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120208/866d9388/attachment.html
