[Qgis-developer] Re: Windows Installation broken - and cannot
uninstall
Andrea Peri
aperi2007 at gmail.com
Wed Feb 8 15:35:20 EST 2012
>* 2. Is it really so necessary to dissuade people from using the OSGeo4W*>* "Setup"?*>* - It is much quicker and easier. E.g. when a new version of QGIS is*>* released you only need to click through setup again to update. You don't*>* need to go to the QGIS website, download a new installer (which will waste*>* time and bandwidth because it is bigger - especially since it includes*>* GRASS, which many people would never use), run the installer, and*>* separately run the uninstaller for the old version.*>* - The OSGeo4W setup also provides easy access to other software you might*>* want to use with QGIS (and nightlies in case you need them :) )*
A problem with the osgeo-setup is that the newbye user could run an
"install all" and so install on its machine the web softwares.
When this was happened , the machine begin to run slow. And the remove of
the web software was a bit of panic, expecially from the services.
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120208/fccd52f9/attachment.html
