[Qgis-developer] Re: [Qgis-user] QGIS WMS client doesn't work
with epsg:31467 and mapserver 6.0.1
Ivan Mincik
ivan.mincik at gmail.com
Thu Feb 9 07:08:10 EST 2012
Hi Otto,
Can you check this issue: http://hub.qgis.org/issues/4946 if it is not
Your problem.
If not, these are my usual steps:
1. Is QGIS indicating in status bar that it is loading some image ? If
not, it can be some problem with extent detection done when loading list
of layers (GetCapabilities request). QGIS is loading images only for
detected extent.
2. If it looks like that QGIS is loading something, but You see only
blank images, you can check WMS server access logs to manually verify
WMS requests send by QGIS (you can paste them here if You are not sure.)
3. Also the usual problem is that WMS server is providing incorrect
GetMap URL or GetFeatureInfo URL. You can set to ignore it in 'Create a
new WMS connection dialog.'
Ivan Mincik
