[Qgis-developer] menu_from_project plugin
Gary Sherman gsherman at geoapt.com
Fri Feb 10 11:06:49 EST 2012
On Feb 10, 2012, at 6:36 AM, Paolo Cavallini wrote:
> Il 10/02/2012 16:31, xcaeag ha scritto:
>> hi,
>> The bugtracker is created:
>> http://hub.qgis.org/projects/menu-from-project/issues
>> The metadata file has been modified a little (in version 0.2.1), maybe that
>> will fix the problem ?
> not for me: I still have 0.2->entries:
> merci
This is from a bug in the metadata.txt file generated by the PluginBuilder. I believe the following line in metadata.txt is the problem:
 # Uncomment the following line and add your changelog entries:
The parser is ignoring the # because of a leading space. Remove the leading space and it should correct the problem.
I am working on an update to the PluginBuilder which will correct this  issue.
-gary
Gary Sherman
GeoApt LLC
  http://geoapt.com
Chair, QGIS PSC
Book:
  http://geospatialdesktop.com
"We work virtually everywhere"
