[Qgis-developer] menu_from_project plugin
CULOS
xavier.culos at eau-adour-garonne.fr
Fri Feb 10 11:13:46 EST 2012
that was it ...
the archive has been corrected.
Thanks
Xavier Culos
Agence de l'eau Adour Garonne
90 rue du Férétra
31078 Toulouse Cedex4
Accéder aux données sur l'eau : http://adour-garonne.eaufrance.fr
> -----Message d'origine-----
> De : qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-
> bounces at lists.osgeo.org] De la part de Gary Sherman
> Envoyé : vendredi 10 février 2012 17:07
> À : cavallini at faunalia.it
> Cc : qgis-developer at lists.osgeo.org
> Objet : Re: [Qgis-developer] menu_from_project plugin
> On Feb 10, 2012, at 6:36 AM, Paolo Cavallini wrote:
> > Il 10/02/2012 16:31, xcaeag ha scritto:
> >> hi,
> >> The bugtracker is created:
> >> http://hub.qgis.org/projects/menu-from-project/issues
> >> The metadata file has been modified a little (in version 0.2.1), maybe
> that
> >> will fix the problem ?
> > not for me: I still have 0.2->entries:
> > merci
> This is from a bug in the metadata.txt file generated by the
> PluginBuilder. I believe the following line in metadata.txt is the
> problem:
> # Uncomment the following line and add your changelog entries:
> The parser is ignoring the # because of a leading space. Remove the
> leading space and it should correct the problem.
> I am working on an update to the PluginBuilder which will correct this
> issue.
> -gary
> Gary Sherman
> GeoApt LLC
> http://geoapt.com
> Chair, QGIS PSC
> Book:
> http://geospatialdesktop.com
> "We work virtually everywhere"
> Qgis-developer mailing list
