[Qgis-developer] a search plugin
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Feb 15 07:52:47 EST 2012
Hi Denis,
any thanks for the plugin, pretty cool.
I'm getting this error
An error has occured while executing Python code:
File "/home/gio/.qgis/python/plugins/qsearch/editsearch.py", line 65,
in on_aliasBox_stateChanged
currentField =
self.fields(aliasMode)[item.fieldCombo.currentIndex()].get('index')
IndexError: list index out of range
when unchecking the option "display only fields with aliases"
cheers
-- Giovanni --
On Tue, 2012-02-14 at 08:49 +0100, Denis Rouzaud wrote:
> Hi all,
> I just published a plugin to perform searches in a layer.
> I know that for many of you this plugin is just a waste of time since
> there is already the SQL advanced search.
> I did this plugin for end-users who have pretty much no idea about
> SQL. With this plugin, you select a layer, and you can add constraints
> to your search using usual vocabulary and also the aliases instead of
> the field names.
> The unique values are listed in an editable combo box for each search
> item.
> You can also save your search to run it later again.
> See also the menu to define settings.
> Please feel free to comment, and suggest improvements.
> http://plugins.qgis.org/plugins/qsearch/
> Btw, I cannot fetch plugin repo 1 in qgis today...
> Cheers,
> Denis
> Qgis-developer mailing list
