[Qgis-developer] a search plugin
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Feb 15 07:57:15 EST 2012
Hi Giovanni,
I think that version 1.0.1 should have fixed this, can you check you
have the last version?
Thanks a lot!
On 02/15/2012 01:52 PM, Giovanni Manghi wrote:
> Hi Denis,
> any thanks for the plugin, pretty cool.
> I'm getting this error
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/gio/.qgis/python/plugins/qsearch/editsearch.py", line 65,
> in on_aliasBox_stateChanged
> currentField =
> self.fields(aliasMode)[item.fieldCombo.currentIndex()].get('index')
> IndexError: list index out of range
> when unchecking the option "display only fields with aliases"
> cheers
> -- Giovanni --
> On Tue, 2012-02-14 at 08:49 +0100, Denis Rouzaud wrote:
>> Hi all,
>> I just published a plugin to perform searches in a layer.
>> I know that for many of you this plugin is just a waste of time since
>> there is already the SQL advanced search.
>> I did this plugin for end-users who have pretty much no idea about
>> SQL. With this plugin, you select a layer, and you can add constraints
>> to your search using usual vocabulary and also the aliases instead of
>> the field names.
>> The unique values are listed in an editable combo box for each search
>> item.
>> You can also save your search to run it later again.
>> See also the menu to define settings.
>> Please feel free to comment, and suggest improvements.
>> http://plugins.qgis.org/plugins/qsearch/
>> Btw, I cannot fetch plugin repo 1 in qgis today...
>> Cheers,
>> Denis
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
