[Qgis-developer] Android qgis alpha5
Hilmy Hashim
hilmyh at gmail.com
Fri Feb 17 07:15:01 EST 2012
I got the same message. I uninstalled the older version and re-installed
the latest alpha and the install was ok.
*Hilmy*
On Fri, Feb 17, 2012 at 7:50 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi Marco,
> Thanks for the note - sounds encouraging.
> I have a strange issue with the install. The Master 5 downloads file and
> then installs for a while. At the end I get a message "Anwendung nicht
> installiert" (application not installed), but with a green checkmark. To
> me the green checkmark looks ok, but why is saying "Anwendung nicht
> installiert"?
> How can I check if the application is equivalent with master5?
> In the about dialogue I don't get a version number. QGIS code revision
> reports as "exported".
> Regarding right-click: where is right click supported? Everywhere where
> it should work (e.g. layer manager) or just for digitizing?
> Thanks,
> Andreas
> On 02/17/2012 11:25 AM, Marco Bernasocchi wrote:
> > Hi all yesterday I pushed a new alpha version of qgis for android on
> > android.qgis.org
> > This release includes all the goodies that I got to implement lately
> > including:
> > - right click support through longClick
> > - shape file support
> > - gps
> > - compass
> > - android 4 support
> > - partial hardware optimization for armV7a (most newish devices have it)
> > - no debug symbols
> > I m very happy with this release because it adresses and fixes all high
> > priority bugs.
> > Adding support for a armv7a optimized whit no debug symbols build
> increased
> > greatly the speed of the app. The package you need to install is the same
> > and includes both armv5 and armv7a code. Android will take care of using
> > the correct version. Gdal and geos are not available yet in v7a code so
> the
> > v5 versions will be loaded.
> > I couldn't test much the v7 code so I hope you can help me testing it.
> > As well, on www.opengis.ch I published many videos and screenshots of
> qgis.
> > As usual, please remember if you can (or if you know anybody that could)
> > that sponsoring would help a lot implementing some more great features.
> > Ciao
> > Marco Bernasocchi (mobile)
> > www.opengis.ch
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120217/6c2bde76/attachment.html
