[Qgis-developer] Android qgis alpha5
Andreas Neumann a.neumann at carto.net
Fri Feb 17 06:50:22 EST 2012
Hi Marco,
Thanks for the note - sounds encouraging.
I have a strange issue with the install. The Master 5 downloads file and
then installs for a while. At the end I get a message "Anwendung nicht
installiert" (application not installed), but with a green checkmark. To
me the green checkmark looks ok, but why is saying "Anwendung nicht
installiert"?
How can I check if the application is equivalent with master5?
In the about dialogue I don't get a version number. QGIS code revision
reports as "exported".
Regarding right-click: where is right click supported? Everywhere where
it should work (e.g. layer manager) or just for digitizing?
Thanks,
Andreas
On 02/17/2012 11:25 AM, Marco Bernasocchi wrote:
> Hi all yesterday I pushed a new alpha version of qgis for android on
> android.qgis.org
> This release includes all the goodies that I got to implement lately
> including:
> - right click support through longClick
> - shape file support
> - gps
> - compass
> - android 4 support
> - partial hardware optimization for armV7a (most newish devices have it)
> - no debug symbols
> I m very happy with this release because it adresses and fixes all high
> priority bugs.
> Adding support for a armv7a optimized whit no debug symbols build increased
> greatly the speed of the app. The package you need to install is the same
> and includes both armv5 and armv7a code. Android will take care of using
> the correct version. Gdal and geos are not available yet in v7a code so the
> v5 versions will be loaded.
> I couldn't test much the v7 code so I hope you can help me testing it.
> As well, on www.opengis.ch I published many videos and screenshots  of qgis.
> As usual, please remember if you can (or if you know anybody that could)
> that sponsoring would help a lot implementing some more great features.
> Ciao
> Marco Bernasocchi (mobile)
> www.opengis.ch
> Qgis-developer mailing list
