[Qgis-developer] Mac OS Build Architecture Setting?
Dan Dittmann
qgis at dandittmann.org
Fri Feb 17 16:33:26 EST 2012
On Feb 17, 2012, at 8:30 AM, William Kyngesburye wrote:
> On Feb 16, 2012, at 11:10 PM, Dan Dittmann wrote:
<snip>
>> /usr/bin/c++ -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk -bundle -Wl,-headerpad_max_install_names -o ../../../PlugIns/qgis/libogrprovider.so CMakeFiles/ogrprovider.dir/qgsogrprovider.cpp.o CMakeFiles/ogrprovider.dir/qgsogrdataitems.cpp.o CMakeFiles/ogrprovider.dir/moc_qgsogrprovider.cxx.o CMakeFiles/ogrprovider.dir/moc_qgsogrdataitems.cxx.o -L/Users/dandittmann/Desktop/qgis-Quantum-GIS/build/src/core -L/Users/dandittmann/Desktop/qgis-Quantum-GIS/build/src/gui ../../../output/lib/qgis_core.framework/Versions/1.9/qgis_core -framework CoreFoundation -framework IOKit /opt/local/lib/libQtXml.dylib /opt/local/lib/libQtCore.dylib /opt/local/lib/libQtGui.dylib /opt/local/lib/libQtNetwork.dylib /opt/local/lib/libQtSvg.dylib -framework PROJ -framework GEOS -framework GDAL -framework SQLite3
> From this, I don't see any way that it can accidentally find a different GDAL than intended. Cmake is very explicit with linking to avoid accidental linking.
> So it's still a mystery. Probably something wierd in Macports. Personally I don't care for Macports (or Fink), and my ultimate advice would be to uninstall it completely and follow the QGIS install instructions for compiling cmake and the other dependencies manually and installing the stock Qt. But it's your choice…
Unfortunately I do use MacPorts for a few other things so it's not going anywhere especially considering I was able to work out a solution. Out of curiousity, I made a few additional attempts/test compiles last night and I think part of the mystery comes down how my $PATH is set. In my case, the usual system stuff (/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin) is processed last so it is fair to assume there is an interaction going on there.
Dan
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
> - Marvin
