[Qgis-developer] Qgis Server not part of standard release?
Dan Dittmann qgis at dandittmann.org
Fri Feb 17 16:50:20 EST 2012
> On Feb 17, 2012, at 11:00 AM, Mike Carsella wrote:
>> Thanks for the info.  I'll try the Windows version.
>> Sent from my mobile
(Trying again as I accidentally sent a reply from the wrong email account causing the message to get bounced.)
It probably is less work to go with the Windows version, but I thought I would point out, if you have MacPorts installed already, you might consider going with that version. A look at the dependencies does show fcgi listed. Unfortunately however, that version does not appear to be getting maintained as it is only at 1.7.0. Given the scenario, I'd probably go with the Windows version as well.
$ port deps qgis
Full Name: qgis @1.7.0_0+postgis+python27
Build Dependencies:   cmake, pkgconfig
Library Dependencies: qt4-mac, libiconv, expat, openssl, proj, geos, gdal,
                     sqlite3, gsl, qwt52, fcgi, py27-pyqt4, postgis
Dan
>> On Feb 14, 2012, at 9:26 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>> I stopped including QGIS mapserver because in OS X 10.7 (Lion) Apple dropped fastcgi (required by mapserver) from their Apache distribution.
>>> When I have time I plan to figure out a way to include it.  While it is possible to compile fastcgi for Apache on Lion, this creates a packaging complexity because Snow Leopard does have fastcgi, and my package is supposed to work on both systems.
>>> On Feb 14, 2012, at 9:41 AM, Mike Carsella wrote:
>>>> I downloaded Qgis 1.7.3 for Mac OS/X 10.6. Qgis_mapserv.fcgi is not included - should it be?  I also tried the iso version - no luck either.  Where can I get Qgis server?
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
>>> "Don't you even hate 'em?"
>>> "What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
>>> <Ha, ha> "And it might give 'em all stomach ulcers."
>>> - Tarzan, on war
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120217/8ba0f9e4/attachment.html
