[Qgis-developer] Call for packaging: QGIS 1.7.4
Larry Shaffer
larrys at dakotacarto.com
Mon Feb 20 01:15:40 EST 2012
Hi Werner,
On Sun, Feb 19, 2012 at 2:39 PM, Werner Macho <werner.macho at gmail.com> wrote:
> Hi Developers and packet assemblers!
> As this is the second release I do now - there are probably some
> glitches that i've not seen.. If there is something wrong with the
> repository or the source package - please report as soon as possible so
> that I can correct the mistakes before any packagers have completed
> their packages.
When building 1_7_4 from archive, on Mac, with a locally installed
libfcgi.dylib, the build errors at the very end due to a typo in
'mac/cmake/2lib.cmake.in' [1]:
CMake Warning at mac/2lib.cmake:114 (IF):
given arguments:
"/usr/local/lib/libfcgi.dylib MATCHES" ".*libfcgi.dylib" "AND"
"NOT" "/usr/local/lib/libfcgi.dylib" "MATCHES" "/usr/lib/.*"
Unknown arguments specified
Call Stack (most recent call first):
mac/cmake_install.cmake:43 (INCLUDE)
cmake_install.cmake:46 (INCLUDE)
Mr. Kyngesburye appears to have fixed this in the master branch
'2lib.cmake.in' file, but it still remains in the 1_7_4 branch.
[1] http://dl.dropbox.com/u/4058089/qgis/master-to-1_7_4-2lib.cmake.in.diff
Also, I can only build from the ZIP archive, not the git fetch (errors
after '[ 43%] Built target qgis_gui'). Will investigate further to see
if it is my setup only.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
