[Qgis-developer] QGIS 1.7.4. crashes on ubuntu 10.04
Agustin Lobo
alobolistas at gmail.com
Mon Feb 20 04:36:19 EST 2012
Hi!
No, I just run the upgrade, which is supposed to remove whatever has
to be removed.
Once I removed libqgis1.7.3, both problems were solved but had
problems with python-gdal.
I have had to downgrade python-gdal from 1.9.0.1 to 1.8.0-2, do not
know why (I thought this problem had been solved).
So, before upgrading to qgis 1.7.4 at least on ubuntu 10.04 64bits,
1. Remove libqgis1.7.3
2. Do not upgrade to python-gdal 1.9.0.1, or, if you do, downgrade to
python-gdal 1.8.0-2 in Synaptic by
2.1. Select pyton-gdal in the package list
2.2. Click on Packages/Force version and select 1.8.0-2
Thanks
Agus
El día 20 de febrero de 2012 10:06, Jürgen E. <jef at norbit.de> escribió:
> Hi Agus,
> On Mon, 20. Feb 2012 at 09:25:04 +0100, Agustin Lobo wrote:
>> Just upgraded to QGIS 1.7.4
> Did you remove the old libqgis1.7.3?
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
