[Qgis-developer] QGIS 1.7.4. crashes on ubuntu 10.04
Sandro Santilli
strk at keybit.net
Mon Feb 20 04:46:48 EST 2012
On Mon, Feb 20, 2012 at 10:23:59AM +0100, Ivan Mincik wrote:
> On 02/20/2012 10:06 AM, Jürgen E. Fischer wrote:
> > Hi Agus,
> > On Mon, 20. Feb 2012 at 09:25:04 +0100, Agustin Lobo wrote:
> >> Just upgraded to QGIS 1.7.4
> > Did you remove the old libqgis1.7.3?
> Jurgen, what can be a solution to these libqgis versions conflicts?
> Adding old versions to debian/control.Conflicts seems not to be a
> solution since we would finish with never ending list of versions.
> Does it make a sense to build it as versioned library if it is not
> possible to successfully run multiple version together ?
Indeed this would be a big step forward.
What does the libqgis1.7.3 library advertises self as ?
It sounds like there's a SONAME equivalence or similar ...
--strk;
