[Qgis-developer] QGIS 1.7.4. crashes on ubuntu 10.04
Etienne Tourigny
etourigny.dev at gmail.com
Mon Feb 20 09:14:13 EST 2012
I agree with Ivan and Sandro.
In master, file debian/control.oneiric contains
Package: libqgis{QGIS_ABI}
The package name should be libqgis1.7 instead of libqgis1.7.3 , with
new versions as packages get updated.
This issue pops up every single release here or in the ubuntu gis
mailing list...
regards,
Etienne
On Mon, Feb 20, 2012 at 6:46 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Mon, Feb 20, 2012 at 10:23:59AM +0100, Ivan Mincik wrote:
>> On 02/20/2012 10:06 AM, Jürgen E. Fischer wrote:
>> > Hi Agus,
>> > On Mon, 20. Feb 2012 at 09:25:04 +0100, Agustin Lobo wrote:
>> >> Just upgraded to QGIS 1.7.4
>> > Did you remove the old libqgis1.7.3?
>> Jurgen, what can be a solution to these libqgis versions conflicts?
>> Adding old versions to debian/control.Conflicts seems not to be a
>> solution since we would finish with never ending list of versions.
>> Does it make a sense to build it as versioned library if it is not
>> possible to successfully run multiple version together ?
> Indeed this would be a big step forward.
> What does the libqgis1.7.3 library advertises self as ?
> It sounds like there's a SONAME equivalence or similar ...
> --strk;
> Qgis-developer mailing list
