[Qgis-developer] Call for packaging: QGIS 1.7.4
Werner Macho werner.macho at gmail.com
Mon Feb 20 18:22:35 EST 2012
Hi Larry,
Ok got it ;) should have thought of that ..
If there will be a 1.7.5 - it will be solved .. but I assume the Mac
packages to be correctly produced ..
In 1.8 and master it is already solved ..
Thanks for the hint
kind regards
Werner
On Mon, 2012-02-20 at 13:37 -0700, Larry Shaffer wrote:
> Hi Werner,
> On Mon, Feb 20, 2012 at 1:59 PM, Werner Macho <werner.macho at gmail.com> wrote:
> > I did take a look in the release-1_7_4 AND release-1_7 branch - both
> > have the patch included ..
> Sorry, Werner, my mistake. I created the diff backwards, from master
> to 1_7_4. There is definitely an error with quotes on line 114 of
> 'mac/cmake/2lib.cmake.in' in both 1_7 and 1_7_4 that keeps
> libfcgi.dylib from being bundled on a Mac build.
> Corrected patch:
> http://dl.dropbox.com/u/4058089/qgis/1_7_4-to-master_2lib.cmake.in.diff
> When the patch is applied to 1_7_4, it compiles without error,
> bundling the libfcgi.dylib into the Mac QGIS.app.
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120221/8bdce8fa/attachment.bin
