[Qgis-developer] QGIS 1.7.4 build fail on Win7
Golubev
golubev at nordcomp.ru
Tue Feb 21 02:05:10 EST 2012
Hi devs!
I can`t build QGIS 1.7.4 in Windows 7 Pro with MSVS 2010 Express and Qt
4.8. Errors appear in qgis_core project:
Generating qgssearchstringparser.cpp
D:/Libs/qgis/1.7.4/src/src/core/qgssearchstringparser.yy: ъюэЇышъЄ√: 15
ёфтшур/т√тюфр
1>D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgsgraduatedsymbolrendererv2.cpp(577):
error C3861: 'time': identifier not found
QGIS 1.7.3 with same settings builds fine.
Log included.
Build started 21.02.2012 10:22:23.
1>Project "D:\Libs\qgis\1.7.4\build-debug\src\core\qgis_core.vcxproj" on node 2 (rebuild target(s)).
1>_PrepareForClean:
Deleting file "qgis_core.dir\Debug\qgis_core.lastbuildstate".
InitializeBuildStatus:
Touching "qgis_core.dir\Debug\qgis_core.unsuccessfulbuild".
CustomBuild:
Generating flex_qgssearchstringlexer.cpp
D:/Libs/qgis/1.7.4/src/src/core/qgssearchstringparser.yy: ъюэЇышъЄ√: 15 ёфтшур/т√тюфр
Generating moc_qgsapplication.cxx
Generating moc_qgscontexthelp.cxx
Generating moc_qgscoordinatetransform.cxx
Generating moc_qgsdataprovider.cxx
Generating moc_qgshttptransaction.cxx
Generating moc_qgsmaplayer.cxx
Generating moc_qgsmaplayerregistry.cxx
Generating moc_qgsmaprenderer.cxx
Generating moc_qgsmessageoutput.cxx
Generating moc_qgscredentials.cxx
Generating moc_qgspluginlayer.cxx
Generating moc_qgsproject.cxx
Generating moc_qgsrunprocess.cxx
Generating moc_qgsvectorlayer.cxx
Generating moc_qgsrasterdataprovider.cxx
Generating moc_qgsnetworkaccessmanager.cxx
Generating moc_qgsvectordataprovider.cxx
Generating composer/moc_qgsaddremoveitemcommand.cxx
Generating composer/moc_qgscomposerlegend.cxx
Generating composer/moc_qgscomposermap.cxx
Generating composer/moc_qgscomposerpicture.cxx
Generating composer/moc_qgscomposerscalebar.cxx
Generating composer/moc_qgscomposeritem.cxx
Generating composer/moc_qgscomposeritemgroup.cxx
Generating composer/moc_qgscomposershape.cxx
Generating composer/moc_qgscomposerattributetable.cxx
Generating composer/moc_qgscomposition.cxx
Generating composer/moc_qgslegendmodel.cxx
Generating symbology/moc_qgsmarkercatalogue.cxx
Generating raster/moc_qgsrasterlayer.cxx
Generating gps/moc_qgsgpsconnection.cxx
Generating gps/moc_qgsgpsdetector.cxx
Generating gps/moc_qgsnmeaconnection.cxx
Generating gps/moc_qgsgpsdconnection.cxx
Generating gps/qextserialport/moc_qextserialport.cxx
Generating gps/qextserialport/moc_qextserialenumerator.cxx
Building Custom Rule D:/Libs/qgis/1.7.4/src/src/core/CMakeLists.txt
CMake does not need to re-run because D:\Libs\qgis\1.7.4\build-debug\src\core\CMakeFiles\generate.stamp is up-to-date.
ClCompile:
C:\Program Files\Microsoft Visual Studio 10.0\VC\bin\CL.exe /c /ID:/Libs/qgis/1.7.4/src/src/core/spatialite/headers/spatialite /IC:/Qt/4.8.0/include /IC:/Qt/4.8.0/include/QtSvg /IC:/Qt/4.8.0/include/QtWebKit /IC:/Qt/4.8.0/include/QtGui /IC:/Qt/4.8.0/include/QtXml /IC:/Qt/4.8.0/include/QtSql /IC:/Qt/4.8.0/include/QtNetwork /IC:/Qt/4.8.0/include/QtCore /I"D:/Libs/qgis/1.7.4/build-debug" /I"D:/Libs/gdal-sdk/release-1600/include" /ID:/Libs/qgis/1.7.4/src/src/core /ID:/Libs/qgis/1.7.4/src/src/core/composer /ID:/Libs/qgis/1.7.4/src/src/core/pal /ID:/Libs/qgis/1.7.4/src/src/core/raster /ID:/Libs/qgis/1.7.4/src/src/core/renderer /ID:/Libs/qgis/1.7.4/src/src/core/symbology /ID:/Libs/qgis/1.7.4/src/src/core/spatialindex/include /I"D:/Libs/qgis/1.7.4/src/src/core/symbology-ng" /ID:/Libs/qgis/1.7.4/src/src/core/gps/qextserialport /Zi /nologo /W4 /WX- /Od /Ob0 /Oy- /D WIN32 /D _WINDOWS /D _DEBUG /D "CORE_EXPORT=__declspec(dllimport)" /D "GUI_EXPORT=__declspec(dllimport)" /D "PYTHON_EXPORT=__declspec(dllimport)" /D "ANALYSIS_EXPORT=__declspec(dllimport)" /D "CORE_EXPORT=__declspec(dllexport)" /D QT_DLL /D QT_SVG_LIB /D QT_WEBKIT_LIB /D QT_GUI_LIB /D QT_XML_LIB /D QT_SQL_LIB /D QT_NETWORK_LIB /D QT_CORE_LIB /D QT_NO_CAST_TO_ASCII /D _USE_MATH_DEFINES /D _CRT_SECURE_NO_WARNINGS /D _CRT_NONSTDC_NO_WARNINGS /D _TTY_WIN_ /D DLL_EXPORT /D _LARGE_FILE=1 /D _FILE_OFFSET_BITS=64 /D _LARGEFILE_SOURCE=1 /D SQLITE_ENABLE_RTREE=1 /D _HAVE_WINDOWS_H_ /D QT_DEBUG /D "CMAKE_INTDIR=\"Debug\"" /D qgis_core_EXPORTS /D _WINDLL /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Fo"qgis_core.dir\Debug\\" /Fd"D:/Libs/qgis/1.7.4/build-debug/src/core/Debug/qgis_core.pdb" /Gd /TP /wd4100 /wd4127 /wd4510 /wd4512 /wd4610 /wd4706 /analyze- /errorReport:prompt D:\Libs\qgis\1.7.4\src\src\core\gps\qextserialport\qextserialport.cpp D:\Libs\qgis\1.7.4\src\src\core\gps\qextserialport\qextserialenumerator.cpp D:\Libs\qgis\1.7.4\src\src\core\gps\qgsgpsconnection.cpp D:\Libs\qgis\1.7.4\src\src\core\gps\qgsgpsconnectionregistry.cpp D:\Libs\qgis\1.7.4\src\src\core\gps\qgsnmeaconnection.cpp D:\Libs\qgis\1.7.4\src\src\core\gps\qgsgpsdconnection.cpp D:\Libs\qgis\1.7.4\src\src\core\gps\qgsgpsdetector.cpp "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgssymbolv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgssymbollayerv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgssymbollayerv2registry.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgssymbollayerv2utils.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgslinesymbollayerv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgsmarkersymbollayerv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgsfillsymbollayerv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgsrendererv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgsrendererv2registry.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgssinglesymbolrendererv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgscategorizedsymbolrendererv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgsgraduatedsymbolrendererv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgsrulebasedrendererv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgsvectorcolorrampv2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgsstylev2.cpp" "D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgssymbologyv2conversion.cpp" D:\Libs\qgis\1.7.4\src\src\core\qgis.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsapplication.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsattributeaction.cpp D:\Libs\qgis\1.7.4\src\src\core\qgscentralpointpositionmanager.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsclipper.cpp D:\Libs\qgis\1.7.4\src\src\core\qgscontexthelp.cpp D:\Libs\qgis\1.7.4\src\src\core\qgscoordinatetransform.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsdatasourceuri.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsdiagram.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsdiagramrendererv2.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsdistancearea.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsfeature.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsfield.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsgeometry.cpp D:\Libs\qgis\1.7.4\src\src\core\qgshttptransaction.cpp D:\Libs\qgis\1.7.4\src\src\core\qgslabel.cpp D:\Libs\qgis\1.7.4\src\src\core\qgslabelattributes.cpp D:\Libs\qgis\1.7.4\src\src\core\qgslabelsearchtree.cpp D:\Libs\qgis\1.7.4\src\src\core\qgslogger.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsmaplayer.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsmaplayerregistry.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsmaprenderer.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsmaptopixel.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsmessageoutput.cpp D:\Libs\qgis\1.7.4\src\src\core\qgscredentials.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsoverlayobject.cpp D:\Libs\qgis\1.7.4\src\src\core\qgspalgeometry.cpp D:\Libs\qgis\1.7.4\src\src\core\qgspallabeling.cpp D:\Libs\qgis\1.7.4\src\src\core\qgspalobjectpositionmanager.cpp D:\Libs\qgis\1.7.4\src\src\core\qgspluginlayer.cpp D:\Libs\qgis\1.7.4\src\src\core\qgspluginlayerregistry.cpp D:\Libs\qgis\1.7.4\src\src\core\qgspoint.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsproject.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsprojectfiletransform.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsprojectversion.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsprojectproperty.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsprovidercountcalcevent.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsproviderextentcalcevent.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsprovidermetadata.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsproviderregistry.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsrasterprojector.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsrasterdataprovider.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsrendercontext.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsrectangle.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsrunprocess.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsscalecalculator.cpp D:\Libs\qgis\1.7.4\src\src\core\qgssearchstring.cpp D:\Libs\qgis\1.7.4\src\src\core\qgssearchtreenode.cpp D:\Libs\qgis\1.7.4\src\src\core\qgssnapper.cpp D:\Libs\qgis\1.7.4\src\src\core\qgscoordinatereferencesystem.cpp D:\Libs\qgis\1.7.4\src\src\core\qgstolerance.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsvectordataprovider.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsvectorfilewriter.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsvectorlayer.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsvectorlayerjoinbuffer.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsvectorlayerundocommand.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsvectoroverlay.cpp D:\Libs\qgis\1.7.4\src\src\core\qgsnetworkaccessmanager.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgsaddremoveitemcommand.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposerarrow.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposeritem.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposeritemcommand.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposeritemgroup.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposerlabel.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposerlegenditem.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposerpicture.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposermap.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposertable.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposerattributetable.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposertexttable.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposerscalebar.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposershape.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgslegendmodel.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposerlegend.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgspaperitem.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgsscalebarstyle.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgsdoubleboxscalebarstyle.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgsnumericscalebarstyle.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgssingleboxscalebarstyle.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgsticksscalebarstyle.cpp D:\Libs\qgis\1.7.4\src\src\core\composer\qgscomposition.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\costcalculator.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\feature.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\geomfunction.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\labelposition.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\layer.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\pal.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\palstat.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\pointset.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\priorityqueue.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\problem.cpp D:\Libs\qgis\1.7.4\src\src\core\pal\util.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgscliptominmaxenhancement.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgscolorrampshader.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgscontrastenhancement.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgscontrastenhancementfunction.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgsfreakoutshader.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgslinearminmaxenhancement.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgslinearminmaxenhancementwithclip.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgspseudocolorshader.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgsrasterlayer.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgsrastertransparency.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgsrastershader.cpp D:\Libs\qgis\1.7.4\src\src\core\raster\qgsrastershaderfunction.cpp D:\Libs\qgis\1.7.4\src\src\core\renderer\qgscontinuouscolorrenderer.cpp D:\Libs\qgis\1.7.4\src\src\core\renderer\qgsgraduatedsymbolrenderer.cpp D:\Libs\qgis\1.7.4\src\src\core\renderer\qgsrenderer.cpp D:\Libs\qgis\1.7.4\src\src\core\renderer\qgssinglesymbolrenderer.cpp D:\Libs\qgis\1.7.4\src\src\core\renderer\qgsuniquevaluerenderer.cpp D:\Libs\qgis\1.7.4\src\src\core\symbology\qgsmarkercatalogue.cpp D:\Libs\qgis\1.7.4\src\src\core\symbology\qgssymbol.cpp D:\Libs\qgis\1.7.4\src\src\core\symbology\qgssymbologyutils.cpp D:\Libs\qgis\1.7.4\src\src\core\spatialindex\qgsspatialindex.cpp D:\Libs\qgis\1.7.4\src\src\core\gps\qextserialport\win_qextserialport.cpp "D:\Libs\qgis\1.7.4\build-debug\src\core\flex_qgssearchstringlexer.cpp" "D:\Libs\qgis\1.7.4\build-debug\src\core\qgssearchstringparser.cpp" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsapplication.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgscontexthelp.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgscoordinatetransform.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsdataprovider.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgshttptransaction.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsmaplayer.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsmaplayerregistry.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsmaprenderer.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsmessageoutput.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgscredentials.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgspluginlayer.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsproject.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsrunprocess.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsvectorlayer.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsrasterdataprovider.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsnetworkaccessmanager.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\moc_qgsvectordataprovider.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgsaddremoveitemcommand.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgscomposerlegend.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgscomposermap.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgscomposerpicture.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgscomposerscalebar.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgscomposeritem.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgscomposeritemgroup.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgscomposershape.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgscomposerattributetable.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgscomposition.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\composer\moc_qgslegendmodel.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\symbology\moc_qgsmarkercatalogue.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\raster\moc_qgsrasterlayer.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\gps\moc_qgsgpsconnection.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\gps\moc_qgsgpsdetector.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\gps\moc_qgsnmeaconnection.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\gps\moc_qgsgpsdconnection.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\gps\qextserialport\moc_qextserialport.cxx" "D:\Libs\qgis\1.7.4\build-debug\src\core\gps\qextserialport\moc_qextserialenumerator.cxx" D:\Libs\qgis\1.7.4\src\src\core\spatialindex\tools\ExternalSort.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\tools\TemporaryFile.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\tools\Tools.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\geometry\LineSegment.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\geometry\Point.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\geometry\Region.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\spatialindex\SpatialIndexImpl.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\storagemanager\Buffer.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\storagemanager\DiskStorageManager.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\storagemanager\MemoryStorageManager.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\storagemanager\RandomEvictionsBuffer.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\rtree\BulkLoader.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\rtree\Index.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\rtree\Leaf.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\rtree\Node.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\rtree\RTree.cc D:\Libs\qgis\1.7.4\src\src\core\spatialindex\rtree\Statistics.cc /Zm1000
qextserialport.cpp
qgsgpsdetector.cpp
qgssymbolv2.cpp
qgsrendererv2.cpp
1>D:\Libs\qgis\1.7.4\src\src\core\symbology-ng\qgsgraduatedsymbolrendererv2.cpp(577): error C3861: 'time': identifier not found
Generating Code...
Compiling...
qgsstylev2.cpp
qgis.cpp
qgsapplication.cpp
qgsclipper.cpp
qgscontexthelp.cpp
qgsdiagram.cpp
qgsdistancearea.cpp
qgsfeature.cpp
qgsfield.cpp
qgsgeometry.cpp
qgslabel.cpp
Generating Code...
1>d:\libs\qgis\1.7.4\src\src\core\qgsgeometry.cpp(5088): warning C4702: unreachable code
1>d:\libs\qgis\1.7.4\src\src\core\qgsgeometry.cpp(5199): warning C4702: unreachable code
1>d:\libs\qgis\1.7.4\src\src\core\qgsgeometry.cpp(5907): warning C4702: unreachable code
1>d:\libs\qgis\1.7.4\src\src\core\qgsgeometry.cpp(5926): warning C4702: unreachable code
1>d:\libs\qgis\1.7.4\src\src\core\qgsgeometry.cpp(5951): warning C4702: unreachable code
1>d:\libs\qgis\1.7.4\src\src\core\qgsclipper.cpp(72): warning C4701: potentially uninitialized local variable 'p1x' used
1>d:\libs\qgis\1.7.4\src\src\core\qgsclipper.cpp(73): warning C4701: potentially uninitialized local variable 'p1y' used
1>d:\libs\qgis\1.7.4\src\src\core\qgsclipper.cpp(88): warning C4701: potentially uninitialized local variable 'lastClipX' used
1>d:\libs\qgis\1.7.4\src\src\core\qgsclipper.cpp(88): warning C4701: potentially uninitialized local variable 'lastClipY' used
Compiling...
qgslogger.cpp
qgsmaplayer.cpp
qgsmaprenderer.cpp
qgsmaptopixel.cpp
qgscredentials.cpp
1>D:\Libs\qgis\1.7.4\src\src\core\qgscredentials.cpp(30): warning C4390: ';' : empty controlled statement found; is this the intent?
qgspalgeometry.cpp
qgspallabeling.cpp
1>D:\Libs\qgis\1.7.4\src\src\core\qgspallabeling.cpp(577): warning C4101: 'e' : unreferenced local variable
1>D:\Libs\qgis\1.7.4\src\src\core\qgspallabeling.cpp(870): warning C4101: 'e' : unreferenced local variable
1>D:\Libs\qgis\1.7.4\src\src\core\qgspallabeling.cpp(960): warning C4101: 'e' : unreferenced local variable
qgspluginlayer.cpp
qgspoint.cpp
qgsproject.cpp
Generating Code...
Compiling...
qgsrectangle.cpp
qgsrunprocess.cpp
qgssearchstring.cpp
qgssnapper.cpp
qgstolerance.cpp
qgsvectorlayer.cpp
1>D:\Libs\qgis\1.7.4\src\src\core\qgsvectorlayer.cpp(779): warning C4101: 'cse' : unreferenced local variable
1>D:\Libs\qgis\1.7.4\src\src\core\qgsvectorlayer.cpp(926): warning C4101: 'cse' : unreferenced local variable
1>D:\Libs\qgis\1.7.4\src\src\core\qgsvectorlayer.cpp(1112): warning C4101: 'cse' : unreferenced local variable
1>D:\Libs\qgis\1.7.4\src\src\core\qgsvectorlayer.cpp(1456): warning C4390: ';' : empty controlled statement found; is this the intent?
1>D:\Libs\qgis\1.7.4\src\src\core\qgsvectorlayer.cpp(1748): warning C4390: ';' : empty controlled statement found; is this the intent?
1>D:\Libs\qgis\1.7.4\src\src\core\qgsvectorlayer.cpp(1850): warning C4390: ';' : empty controlled statement found; is this the intent?
Generating Code...
Compiling...
qgscomposeritem.cpp
qgscomposermap.cpp
qgslegendmodel.cpp
qgspaperitem.cpp
Generating Code...
Compiling...
qgscomposition.cpp
costcalculator.cpp
feature.cpp
geomfunction.cpp
labelposition.cpp
layer.cpp
pal.cpp
palstat.cpp
pointset.cpp
priorityqueue.cpp
problem.cpp
util.cpp
Generating Code...
Compiling...
qgsrasterlayer.cpp
qgsrastershader.cpp
qgsrenderer.cpp
qgssymbol.cpp
qgsspatialindex.cpp
Generating Code...
Compiling...
moc_qgsmaplayer.cxx
moc_qgsproject.cxx
Generating Code...
Compiling...
ExternalSort.cc
TemporaryFile.cc
Tools.cc
LineSegment.cc
Point.cc
Generating Code...
Compiling...
Region.cc
SpatialIndexImpl.cc
Buffer.cc
BulkLoader.cc
Index.cc
Leaf.cc
Node.cc
RTree.cc
Statistics.cc
Generating Code...
1>Done Building Project "D:\Libs\qgis\1.7.4\build-debug\src\core\qgis_core.vcxproj" (rebuild target(s)) -- FAILED.
Build FAILED.
Time Elapsed 00:02:05.67
