[Qgis-developer] Building Qgis on centos6
Zirneklitis
eko at lanet.lv
Tue Feb 21 04:04:57 EST 2012
The orginal message mentioned 1.7.2.
Just an hour ago I have compiled 1.9.90-Alpha with same error message
(on Fedora 14 x64). Full path for GDAL_LIBRARY has to be used.
Z.
Werner Macho wrote:
> Hi!
> As I can see you are using version 1.7.2 .. there is already 1.7.4 (not
> official right now - but soon official) out there ..
> Can you try this version to compile or are you bound to 1.7.2 ..
> kind regards
> Werner
> by version 1.7.4 On Tue, 2012-02-21 at 08:45 +0200, Zirneklitis wrote:
>> Hi,
>> There was a message on Wed Dec 7 08:48:41 EST 2011 :
>> > the error is
>> > make[2]: *** No rule to make target `/libgdal.so', needed by
>> > `src/core/libqgis_core.so.1.7.2'. Stop.
>> > make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
>> > make: *** [all] Error 2
>> The problem is in ccmake configuration. The parameter
>> GDAL_LIBRARY /libgdal.so
>> should be changed according to the system, e.g.
>> GDAL_LIBRARY /usr/lib64/libgdal.so
>> Best regards,
>> Z.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
