[Qgis-developer] Building Qgis on centos6
Werner Macho
werner.macho at gmail.com
Tue Feb 21 04:06:18 EST 2012
Hi!
As I can see you are using version 1.7.2 .. there is already 1.7.4 (not
official right now - but soon official) out there ..
Can you try this version to compile or are you bound to 1.7.2 ..
kind regards
Werner
by version 1.7.4 On Tue, 2012-02-21 at 08:45 +0200, Zirneklitis wrote:
> Hi,
> There was a message on Wed Dec 7 08:48:41 EST 2011 :
> > the error is
> > make[2]: *** No rule to make target `/libgdal.so', needed by
> > `src/core/libqgis_core.so.1.7.2'. Stop.
> > make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> > make: *** [all] Error 2
> The problem is in ccmake configuration. The parameter
> GDAL_LIBRARY /libgdal.so
> should be changed according to the system, e.g.
> GDAL_LIBRARY /usr/lib64/libgdal.so
> Best regards,
> Z.
> Qgis-developer mailing list
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120221/ce5dbc03/attachment.bin
