[Qgis-developer] Building Qgis on centos6
Volker Fröhlich
volker27 at gmx.at
Tue Feb 21 03:06:37 EST 2012
Am Dienstag, 21. Februar 2012, 08:45:04 schrieb Zirneklitis:
> Hi,
> There was a message on Wed Dec 7 08:48:41 EST 2011 :
> > the error is
> > make[2]: *** No rule to make target `/libgdal.so', needed by
> > `src/core/libqgis_core.so.1.7.2'. Stop.
> > make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> > make: *** [all] Error 2
If you're not trying to build the trunk version, may I suggest to just rebuild
the Fedora package or use the package from ELGIS? This approach is a lot
easier and cleaner.
http://hub.qgis.org/projects/quantum-gis/wiki/Download#RHEL-CentOS-Scientific-
Linux-
Volker
> The problem is in ccmake configuration. The parameter
> GDAL_LIBRARY /libgdal.so
> should be changed according to the system, e.g.
> GDAL_LIBRARY /usr/lib64/libgdal.so
> Best regards,
> Z.
> Qgis-developer mailing list
