[Qgis-developer] OS X 1.7.4... bomb
Alex Mandel tech_dev at wildintellect.com
Sat Feb 25 14:03:38 EST 2012
On 02/25/2012 07:24 AM, William Kyngesburye wrote:
> WARNING #2: delete existing plugins before running QGIS 1.7.4.  If you can do it before installing QGIS, disable them in the old QGIS, then update and re-enable them one at a time after upgrading QGIS.  If you have already installed 1.7.4, you need to manually delete them from ~/.qgis/python/plugins.
> I've had a report of plugins directly using a specific GDAL version like 1.8 (I don't know how this is possible), which will crash QGIS 1.7.4 which uses GDAL 1.9.  There also appears to be a problem with PyQwt so the profile plugin will crash QGIS.
GDALTools perhaps, as I recall on Mac often times the path to GDAL has
to be manually set and on upgrade could easily still refer to the old
version in it's settings. Does manually editing the setting before
trying to run a Raster tool solve the issue? (Please pass that on to
whomever reported the issue)
Thanks,
Alex
