[Qgis-developer] Offset curve tool
Denis Rouzaud denis.rouzaud at gmail.com
Wed Feb 29 08:54:58 EST 2012
Seems possible, as the bug appears when one segment of the line is
getting very very small.
On 02/29/2012 02:45 PM, Marco Hugentobler wrote:
> Hi Denis
> In certain cases, geos trunk throws an exception (version 3.2 crashes):
> ERROR 1: IllegalArgumentException: RobustDeterminant encountered
> non-finite numbers
> I noticed it happens often with lines with dense vertex distributions
> (e.g. segmented curves). Maybe Sandro (strk) knows more about the
> details?
> Regards,
> Marco
> On 29.02.2012 14:28, Denis Rouzaud wrote:
>> Hi Marco,
>> I noticed a bug and Qgis crashes.
>> Here is a video http://youtu.be/DBbMg5rO8fU
>> The geometry of the line I played with is:
>> LINESTRING(554235.01669295 145547.73137862,554242.99020772
>> 145548.76938867,554245.33776182 145545.30016923,554245.49416371
>> 145544.76210759)
>> Greetings,
>> Denis
>> On 02/29/2012 11:11 AM, Marco Hugentobler wrote: Hi all
>> There is a new editing tool in the master branch.
>> The offset curve tool creates parallel shifts of linestrings and
>> polygon rings ( single sided buffers with the geos function
>> GEOSSingleSidedBuffer ). The tool can be applied to the edited layer
>> (the geometries are modified) or also to background layers (creates
>> copies of the lines / rings and adds it to the the edited layer). It
>> is thus ideally suited for the creation of distance line layers.
>> Let me know about issues, suggestions, comments.
>> The work was kindly funded by the city of Uster (Switzerland).
>> Regards,
>> Marco
>>> Hi all
>>> Regards,
>>> Marco
