[Qgis-developer] r.in.gdal.qgis.loc problem
Paolo Cavallini
cavallini at faunalia.it
Wed Jan 4 07:27:51 EST 2012
Hi all.
The (quite handy) command has a problem:
- the location is created
- the raster is imported in it
- but the current location is not switched, therefore one gets an error
(below).
If anyone confirms, I can open a ticket.
All the best.
Impossibile recuperare informazioni sulla mappa
Impossibile far funzionare il modulo
comando: /usr/lib/qgis/grass/modules/qgis.g.info info=info
rast=lidar_2011 at paolo<br>TYPE:-1
<br>
GRASS_INFO_WARNING(8936,1): Raster <lidar_2011 at paolo> non trovato
GRASS_INFO_END(8936,1)
GRASS_INFO_WARNING(8936,2): Raster <lidar_2011 at paolo> non trovato
GRASS_INFO_END(8936,2)
GRASS_INFO_WARNING(8936,3): non riesco a leggere il file f_range per
[lidar_2011 at paolo in ]
GRASS_INFO_END(8936,3)
GRASS_INFO_ERROR(8936,4): Unable to read range file
GRASS_INFO_END(8936,4)
Paolo Cavallini
See: http://www.faunalia.it/pc
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120104/ec9b0149/attachment.html
