[Qgis-developer] How to debug and unit test Python plugins
outside QGIS (e.g. in Ecplise IDE + PyDev)
Tim Sutton
lists at linfiniti.com
Tue Jan 10 14:44:49 EST 2012
Hi
2012/1/10 Germán Carrillo <carrillo.german at gmail.com>:
> Hi,
> you can find an example at [1], namely a class called "QgisInterface" in the
> postgis_viewer.py, line 313.
Awesome thanks! Testing it now....
Regards
Tim
> Hope it helps.
> Regards,
> Germán
> [1]
> http://downloads.tuxfamily.org/tuxgis/geoblogs/visor_postgis_pgadmin_3/postgis_viewer.zip
> 2012/1/10 Tim Sutton <lists at linfiniti.com>
>> Hi
>> On Tue, Jan 10, 2012 at 7:08 PM, Martin Dobias <wonder.sk at gmail.com>
>> wrote:
>> >> On Thu, Mar 3, 2011 at 10:40 AM, Martin Dobias <wonder.sk at gmail.com>
>> >> wrote:
>> >>> The only difference when running unit-tests (i.e. standalone apps) is
>> >>> that you cannot access QGIS interface (qgis.utils.iface) since there
>> >>> is no QGIS running. But that should not pose a big problem. In case
>> >>> you really need access to that interface you can create your own
>> >>> implementation of QgisInterface class and assign it to
>> >>> qgis.utils.iface.
>> >>> Regards
>> >>> Martin
>> >> Martin do you (or anyone else) have example code for creating an iface
>> >> instance from a standalone python / QGIS app?
>> > Hi Tim
>> > no I do not have a working example. In general it should be something
>> > like this:
>> > import qgis.utils
>> > import qgis.gui
>> > class MyQgisInterface(qgis.gui.QgisInterface):
>> > def __init__(self):
>> > QgisInterface.__init__(self)
>> > def mapCanvas(self):
>> > return FOO
>> > def mainWindow(self):
>> > return BAR
>> > def activeLayer(self):
>> > return BAZ
>> > # ... more methods ...
>> > # use our interface instance
>> > qgis.utils.iface = MyQgisInterface()
>> > You will have to provide implementation of all the abstract virtual
>> > functions defined in QgisInterface. Luckily most of them are not used
>> > by plugins, so you may provide just implementations not
>> > doing/returning anything - depending on how precisely would you like
>> > to imitate QGIS environment.
>> Thanks Martin. Yes I have used the same approach in openModeller
>> desktop some years ago to allow it to use QGIS (C++) plugins - I was
>> just interested to know if someone had already baked a python
>> equivalent in keeping with DRAY (dont repeat anyone else :-)).
>> I'll go ahead and make an attempt at a python one then, thanks.
>> Regards
>> Tim
>> > Regards
>> > Martin
>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
Skype: timlinux
