[Qgis-developer] How to debug and unit test Python plugins
outside QGIS (e.g. in Ecplise IDE + PyDev)
Stefan Keller
sfkeller at gmail.com
Tue Jan 10 17:52:53 EST 2012
Hi all
Regarding the initial thread: I finally managed to debug and unit test
Python plugins outside QGIS with Ecplise IDE and PyDev under Windows.
It's documented here (I'm sorry it's german and not yet english):
http://www.gis.hsr.ch/wiki/QGIS_Plugins_mit_Python#Debugging_von_Python-QGIS-Plugins_mit_Eclipse
Stefan
2012/1/10 Tim Sutton <lists at linfiniti.com>:
> Hi
> 2012/1/10 Germán Carrillo <carrillo.german at gmail.com>:
>> Hi,
>> you can find an example at [1], namely a class called "QgisInterface" in the
>> postgis_viewer.py, line 313.
> Awesome thanks! Testing it now....
> Regards
> Tim
>> Hope it helps.
>> Regards,
>> Germán
>> [1]
>> http://downloads.tuxfamily.org/tuxgis/geoblogs/visor_postgis_pgadmin_3/postgis_viewer.zip
>>> Hi
>>> On Tue, Jan 10, 2012 at 7:08 PM, Martin Dobias <wonder.sk at gmail.com>
>>> wrote:
>>> >> On Thu, Mar 3, 2011 at 10:40 AM, Martin Dobias <wonder.sk at gmail.com>
>>> >> wrote:
>>> >>> The only difference when running unit-tests (i.e. standalone apps) is
>>> >>> that you cannot access QGIS interface (qgis.utils.iface) since there
>>> >>> is no QGIS running. But that should not pose a big problem. In case
>>> >>> you really need access to that interface you can create your own
>>> >>> implementation of QgisInterface class and assign it to
>>> >>> qgis.utils.iface.
>>> >>> Regards
>>> >>> Martin
>>> >> Martin do you (or anyone else) have example code for creating an iface
>>> >> instance from a standalone python / QGIS app?
>>> > Hi Tim
>>> > no I do not have a working example. In general it should be something
>>> > like this:
>>> > import qgis.utils
>>> > import qgis.gui
>>> > class MyQgisInterface(qgis.gui.QgisInterface):
>>> > def __init__(self):
>>> > QgisInterface.__init__(self)
>>> > def mapCanvas(self):
>>> > return FOO
>>> > def mainWindow(self):
>>> > return BAR
>>> > def activeLayer(self):
>>> > return BAZ
>>> > # ... more methods ...
>>> > # use our interface instance
>>> > qgis.utils.iface = MyQgisInterface()
>>> > You will have to provide implementation of all the abstract virtual
>>> > functions defined in QgisInterface. Luckily most of them are not used
>>> > by plugins, so you may provide just implementations not
>>> > doing/returning anything - depending on how precisely would you like
>>> > to imitate QGIS environment.
>>> Thanks Martin. Yes I have used the same approach in openModeller
>>> desktop some years ago to allow it to use QGIS (C++) plugins - I was
>>> just interested to know if someone had already baked a python
>>> equivalent in keeping with DRAY (dont repeat anyone else :-)).
>>> I'll go ahead and make an attempt at a python one then, thanks.
>>> Regards
>>> Tim
>>> > Regards
>>> > Martin
>>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>>> Please do not email me off-list with technical
>>> support questions. Using the lists will gain
>>> more exposure for your issues and the knowledge
>>> surrounding your issue will be shared with all.
>>> Visit http://linfiniti.com to find out about:
>>> * QGIS programming and support services
>>> * Mapserver and PostGIS based hosting plans
>>> * FOSS Consulting Services
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> |\__
>> (:>__)(
>> Soluciones Geoinformáticas Libres
>> http://geotux.tuxfamily.org/
> Skype: timlinux
