[Qgis-developer] GRASS rasters: color table not applied?
Radim Blazek
radim.blazek at gmail.com
Wed Jan 11 15:26:24 EST 2012
Could you try to run qgis.g.info in GRASS shell on your raster:
your_path_to_qgis_dir/lib/qgis/grass/modules/qgis.g.info
info=colors rast=your_raster
it should output color table, something like
1.000000e+00 5.500000e+00 0 255 0 255 255 0
5.500000e+00 1.000000e+01 255 255 0 255 0 0
Do you have the same problem on more computers?
Radim
On Sun, Jan 8, 2012 at 10:44 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il 06/01/2012 12:40, Radim Blazek ha scritto:
>> For me it works with all data types and current master.
>> Does it work correctly in GRASS monitor?
> yes
>> Are you using some particular rules or a predefined one?
> I tried with several predefined rules, same result.
>> Have you checked if the generated color table itself looks correctly?
> Yes.
>> Does it work if you add the map to QGIS again instead of just refresh?
> Not.
>> Is it the color table loaded into QGIS (colormap in properties)?
> Not.
> Please note: loading the map in QGIS takes an enormous time (several
> minutes), in GRASS is fast.
>> Is it style set correctly in style tab (colormap)?
> Not (it remains grey).
>> Does it work if you convert the same map to GDT_Float64 ( r.mapcalc
>> m64=double(m32) )?
> Yes.
> Thanks.
> Paolo Cavallini
> See: http://www.faunalia.it/pc
