[Qgis-developer] GRASS rasters: color table not applied?
Paolo Cavallini
cavallini at faunalia.it
Sun Jan 8 04:44:55 EST 2012
Il 06/01/2012 12:40, Radim Blazek ha scritto:
> For me it works with all data types and current master.
> Does it work correctly in GRASS monitor?
yes
> Are you using some particular rules or a predefined one?
I tried with several predefined rules, same result.
> Have you checked if the generated color table itself looks correctly?
Yes.
> Does it work if you add the map to QGIS again instead of just refresh?
Not.
> Is it the color table loaded into QGIS (colormap in properties)?
Not.
Please note: loading the map in QGIS takes an enormous time (several
minutes), in GRASS is fast.
> Is it style set correctly in style tab (colormap)?
Not (it remains grey).
> Does it work if you convert the same map to GDT_Float64 ( r.mapcalc
> m64=double(m32) )?
Yes.
Thanks.
Paolo Cavallini
See: http://www.faunalia.it/pc
