[Qgis-developer] Expression builder in field calculator
Nathan Woodrow madmanwoo at gmail.com
Mon Jan 16 10:03:39 EST 2012
Thanks Tim,
I'll give it a test in the morning and I'll that routine against mine to
check what I might have changed by accident.
- Nathan
On Tue, Jan 17, 2012 at 1:01 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Mon, Jan 16, 2012 at 3:18 PM, Paolo Cavallini <cavallini at faunalia.it>
> wrote:
> > Il 16/01/2012 13:44, Nathan Woodrow ha scritto:
> >> Tim,
> >> Bugger, I'll check it out.
> Ok I can replicate - procedure to replicate:
> Populate a real field with a constant e.g. 1.5
> Save layer
> Edit layer again
> Open calculator
> Tick update existing field
> Field: currentdep
> Enter this formula:
>  "currentdep"  / 3
> (note that the field is self referenced, i.e. its referencing the
> field it is updating).
> Also note the buttonbox is not stretching all the way across the dialog.
> Regards
> Tim
> > Rather obvious from my side, but:
> > +1 for pushing it to master.
> > All the best.
> > Paolo Cavallini - Faunalia
> > www.faunalia.eu
> > Full contact details at www.faunalia.eu/pc
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120117/ff69a27f/attachment.html
