[Qgis-developer] Rule based labeling
Andreas Neumann a.neumann at carto.net
Tue Jan 24 10:06:10 EST 2012
 Hi Martin,
 Thanks for the pointer.
 In my experience, the labeling is often (most of the time) disconnected
 from other symbolization rules. Generally I need fewer rules for
 labeling as I am using for the general symbolization.
 So in my opinion the two should not be linked together.
 Andreas
 On Tue, 24 Jan 2012 15:42:06 +0100, Martin Dobias wrote:
> On Mon, Jan 23, 2012 at 5:41 PM, Andreas Neumann
> <a.neumann at carto.net> wrote:
>> What I would need:
>> if rule A applies, I'll have these font settings
>> if rule B applies, I'll have these font settings
>> etc.
>> Also, it would be nice to have different labels for different scale
>> ranges
>> (e.g. different label text) for another scale range.
>> How hard would it be to implement such rule-based labeling?
> Hi Andreas
> Nathan has outlined two possibilities here:
> http://hub.qgis.org/projects/quantum-gis/wiki/RuleBasedLabelingIdeas
> Both have some pros and cons, both are doable. The scenario when
> labeling rules are independent from layer symbology is probably more
> straightforward to implement and easier to use with only few rules
> for
> labels. On the other hand, if labels were attached to symbols, the
> fine-grained labeling settings would not require duplicate rules for
> symbology and labeling.
> Regards
> Martin
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
