[Qgis-developer] my first python plugin for qgis
Denis Rouzaud denis.rouzaud at gmail.com
Wed Jan 25 04:12:12 EST 2012
Hi Stefan,
Yes, the situation is a little bit tricky right now.
Creating a project on the hub (i.e. redmine) is not mandatory. But it
can be used to host the code repository (as github does) and the
issue/bug tracker.
Login and create one here if you want: http://hub.qgis.org/projects
You will not be able to place it in the plugin project, it should be
moved by an admin later.
For the validation, I understand your frustration. I uploaded an update
24h ago, and it is not released yet.
For all, do you really think that this validation is useful? Maybe for
first upload, but then remove it?
Cheers,
Denis
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120125/43cb8488/attachment.html
