[Qgis-developer] Re: [Qgis-user] knock knock - 1.7.4 is outside
Werner Macho
werner.macho at gmail.com
Thu Jan 26 09:47:46 EST 2012
On Thu, 2012-01-26 at 14:43 +0000, Giovanni Manghi wrote:
> Hi Werner, all
> > Thats what I like to find out with my "Call for testing" ..
> > I think if the branch gets well tested on different data we'll see if
> > there are more bugs inside than in 1.7.3 :) .. At least I think 1.7.4
> > will be better than 1.7.3 allthough it is obvious that not everything
> > can be fixed ..
> I'm available to "lead" a small team of testers in order to check for
> regressions and (new) critical bugs (causing crashes or data corruption)
> before releasing. Strictly from a user point of view.
> cheers
> -- Giovanni --
Thanks a lot for your help Giovanni!!
As I told you already I think I do not have enough critical data to
really test all user cases - so a small team would be fine..
I'll wait for your feedback .. try to solve all reported problems - and
afterwards do a release ..
Please keep in mind that we do not backport new features .. some
reported bugs are solved by introducing new features ..
Thats what 1.8 will be for ..
So thanks again a lot .. Let's try to catch all possible bugs ..
kind regards
Werner
