[Qgis-developer] Re: [Qgis-user] knock knock - 1.7.4 is outside
kimaidou
kimaidou at gmail.com
Thu Jan 26 13:43:56 EST 2012
Hi all
I will also try to compile the 1.7.4 on my ubuntu and open the projects I
am working with now, and report possible downgrades/bugs.
Michael
2012/1/26 Werner Macho <werner.macho at gmail.com>
> On Thu, 2012-01-26 at 14:43 +0000, Giovanni Manghi wrote:
> > Hi Werner, all
> > > Thats what I like to find out with my "Call for testing" ..
> > > I think if the branch gets well tested on different data we'll see if
> > > there are more bugs inside than in 1.7.3 :) .. At least I think 1.7.4
> > > will be better than 1.7.3 allthough it is obvious that not everything
> > > can be fixed ..
> > I'm available to "lead" a small team of testers in order to check for
> > regressions and (new) critical bugs (causing crashes or data corruption)
> > before releasing. Strictly from a user point of view.
> > cheers
> > -- Giovanni --
> Thanks a lot for your help Giovanni!!
> As I told you already I think I do not have enough critical data to
> really test all user cases - so a small team would be fine..
> I'll wait for your feedback .. try to solve all reported problems - and
> afterwards do a release ..
> Please keep in mind that we do not backport new features .. some
> reported bugs are solved by introducing new features ..
> Thats what 1.8 will be for ..
> So thanks again a lot .. Let's try to catch all possible bugs ..
> kind regards
> Werner
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120126/891d0aac/attachment.html
