[Qgis-developer] Zoom to Best Scale Problem
Giovanni Manghi
giovanni.manghi at gmail.com
Fri Jan 27 14:11:52 EST 2012
Known issue, there is a patch in the bug tracker that should solve it
http://hub.qgis.org/issues/3609
On Fri, 2012-01-27 at 14:04 -0500, Jeff Ruby wrote:
> Hi,
> On 1.7.3 'Zoom to Best Scale' does not seem to work properly when
> 'Enable on the fly CRS transformation' is enabled in Project
> Properties. If 'Enable on the fly CRS transformation' is checked,
> 'Zoom to Best Scale' zooms beyond 1:1. If 'Enable on the fly CRS
> transformation' is unchecked 'Zoom to Best Scale' zooms to 1:1
> correctly. My project and imagery are both in EPSG:32618 (UTM 18N,
> WGS84).
> I do observe the same problem on 1.6.
> I'm using 1.7.3 on Windows 7.
> Thanks,
> -Jeff
> Qgis-developer mailing list
