[Qgis-developer] Zoom to Best Scale Problem
Alexander Bruy
alexander.bruy at gmail.com
Fri Jan 27 14:11:31 EST 2012
Hi Jeff,
this issue already reported, see [0].
[0] http://hub.qgis.org/issues/3609
2012/1/27 Jeff Ruby <jgr007 at gmail.com>:
> Hi,
> On 1.7.3 'Zoom to Best Scale' does not seem to work properly when
> 'Enable on the fly CRS transformation' is enabled in Project
> Properties. If 'Enable on the fly CRS transformation' is checked,
> 'Zoom to Best Scale' zooms beyond 1:1. If 'Enable on the fly CRS
> transformation' is unchecked 'Zoom to Best Scale' zooms to 1:1
> correctly. My project and imagery are both in EPSG:32618 (UTM 18N,
> WGS84).
> I do observe the same problem on 1.6.
> I'm using 1.7.3 on Windows 7.
Alexander Bruy
