[Qgis-developer] Unable to push code to a git repository on hub.qgis.org
Giuseppe Sucameli
brush.tyler at gmail.com
Tue Jul 3 10:47:52 PDT 2012
Hi all,
further notes:
- It's not due to the ssh public key, I'm able to push to the other
repos on hub.
- I executed "git push origin master" without any initial commit
(empty git repo) because I copied/pasted the code on the Repository
section.
BTW now I've some commits but the problem persists.
- I deleted the local git repository (2 times) to be sure it doesn't
depend on mess in the local repo.
Perhaps deleting the git repo from the server could fix the
problem, but I don't know if it's feasible.
Does anybody know how to make it working?
Thanks a lot.
Regards.
On Tue, Jul 3, 2012 at 3:00 PM, Giuseppe Sucameli <brush.tyler at gmail.com> wrote:
> Hi all,
> I've set up a code repository on hub.qgis.org for a plugin I'm
> working on, but I'm unable to push the code to the remote repo.
> The plugin identifier on hub is "gem-mt".
> Here's the error message I get:
> <pre>
> ~/projects/gem_mt$ git push origin master
> ERROR:gitosis.serve.main:Repository read access denied
> fatal: The remote end hung up unexpectedly
> </pre>
> It's not the first plugin I move to hub, so I'm sure that I've made
> all the correct setup except for one thing, I tried to push the code
> without granting me Developer permissions.
> But after adding Developer role to my user in the Member tab
> I still get the same error, perhaps it was cached somewhere.
> I've dropped and re-created the local repository, but the issue
> persists and there's no way to drop the remote repository from
> the hub.qgis.org site.
> Any idea on how to achieve it?
> Regards.
> Giuseppe Sucameli
Giuseppe Sucameli
