[Qgis-developer] Unable to push code to a git repository on hub.qgis.org
    Salvatore Larosa
    lrssvtml at gmail.com
    Tue Jul  3 14:23:13 PDT 2012
Hi Giuseppe,
Il giorno mar, 03/07/2012 alle 15.00 +0200, Giuseppe Sucameli ha
scritto:
> Hi all,
> I've set up a code repository on hub.qgis.org for a plugin I'm
> working on, but I'm unable to push the code to the remote repo.
> The plugin identifier on hub is "gem-mt".
> Here's the error message I get:
> <pre>
> ~/projects/gem_mt$ git push origin master
> ERROR:gitosis.serve.main:Repository read access denied
> fatal: The remote end hung up unexpectedly
> </pre>
Maybe a problem of permissions ?
Have a look here [1] and [2]
Hope this helps!
> It's not the first plugin I move to hub, so I'm sure that I've made
> all the correct setup except for one thing, I tried to push the code
> without granting me Developer permissions.
> But after adding Developer role to my user in the Member tab
> I still get the same error, perhaps it was cached somewhere.
> I've dropped and re-created the local repository, but the issue
> persists and there's no way to drop the remote repository from
> the hub.qgis.org site.
> Any idea on how to achieve it?
> Regards.
All the best!
[1] - http://urlin.it/331a1
[2] - http://urlin.it/331a2
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
