[Qgis-developer] [Qgis-user] Cast your vote: Default icon theme for QGIS 2.0
Daniel Lee
lee at isi-solutions.org
Tue Jul 10 23:49:25 PDT 2012
What if the add layer buttons were unified - one button that would then
give you the option of adding a shapefile, database table, directory, GRASS
map, etc.? That could consolidate and eliminate a lot of the confusion.
2012/7/10 Micha Silver <micha at arava.co.il>
> A question regarding the plans for the QGIS icon theme and the GRASS
> plugin.
> Currently GRASS (standalone) uses Robert's icons, but the QGIS plugin with
> the default theme uses other icons. That already could be a small bit of
> confusion. But when I switch QGIS to the new GIS theme, then some of the
> icons appear duplicated: Add Vector in QGIS and Add GRASS vector use the
> same icon. Another possible source of confusion.
> I'm not sure what I'd suggest to make everything work uniformly. It would
> be ideal if the GRASS application icons were identical to the GRASS plugin
> icons, but *different* from the generic QGIS "Add Vector" and "Add raster".
> Micha
> On 07/10/2012 01:50 PM, Anita Graser wrote:
> You can get a good overview over Robert's work at
> http://robert.szczepanek.pl/icons.php
> Anita
> On Tue, Jul 10, 2012 at 12:41 PM, Martin Landa <landa.martin at gmail.com>wrote:
>> Hi,
>> 2012/7/10 Daniel Lee <lee at isi-solutions.org>:
>> > I also think the GRASS theme is great, although I have to say that I'm a
>> it's not a "GRASS theme". wxGUI just uses part of icons from [1] which
>> was designed by Robert Szczepanek as a generic GIS-related icon set
>> (AFAIU).
>> Martin
>> [1] https://svn.osgeo.org/osgeo/graphics/trunk/toolbar-icons/24x24/
>> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> This mail was received via Mail-SeCure System.
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> Micha Silver
> GIS Consultant, Arava Development Co.http://www.surfaces.co.il
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120711/093ae408/attachment.html>
