[Qgis-developer] What will be in QGIS 2.0
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Wed Jul 11 07:21:40 PDT 2012
>- Threading branch and threaded data provider refactor (a long time
>ago in GSOC project far away Martin Dobias got much of the ground work
>in place but the delta between his branch and master is huge now)
As you mention, a large part of the work is the data provider
refactoring (implementing the iterator pattern for every provider).
On the other hand, it is a task that can be parallelized. If each
maintainer of a vector provider could implement that for his
provider(s), that would make the whole process much easier. I'm
available to change the WFS provider.
What do others think?
Regards,
Marco
Am 11.07.2012 13:26, schrieb Tim Sutton:
> Hi All
> Marco and I have been discussing version 2.0 and wanted to bring the
> discussion onto the list. In particular we are interested in:
> - When is a reasonable date to aim for the release?
> - What features will be part of 2.0?
> - What things are we going to clean away for the release?
> Here are a list of the possible things that could go into 2.0 that we
> came up with:
> - QgsGeometry Refactor to support arcs, measures, 3d geometries and
> geometry collections (Marco is working on this though unless he is
> funded to work on it it is unlikely to happen for 2.0)
> - Raster refactor to use new renderer architecture, native WCS
> support, pipelines, 'save as' support and more (this work is being
> funded by the World Bank and will be available in master over the next
> 3 months)
> - GSOC project for symbology UI redesign / improvements (how is this
> work going?)
> - GSOC project for on the fly feature generalization (also how is this going)
> - Addition of Sextante into QGIS as a standard plugin (assuming that
> sits well with Victor)
> What else do we miss from the list? Are any others out there actively
> working on features / funding features that we should be aware of?
> In terms of decrufting, it would be good to remove all the duplicated items:
> - twin labelling systems
> - unified add layer dialogs
> - twin symbology systems
> - about 15 ways to generate hillshades
> - too many toolbars / icons by default
> - remove all deprecated calls from the API
> Are there any other things that folks would like to add to the
> discussion for the roadmap for version 2.0?
> Regards
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
