[Qgis-developer] What will be in QGIS 2.0
Germán Carrillo
carrillo.german at gmail.com
Wed Jul 11 07:59:57 PDT 2012
Hi all,
please don't forget the QGIS legend and its issues when keeping track of
both layer and group positions.
Since there could be too many new functionalities, what about publishing a
survey in qgis.org for prioritizing and, perhaps, postponing them for minor
2.x releases?
Focusing on too many new stuff could yield the
next-major-version-is-coming-since-several-years-ago problem that other GIS
software have experienced.
Regards,
Germán
2012/7/11 Marco Hugentobler <marco.hugentobler at sourcepole.ch>
> - Threading branch and threaded data provider refactor (a long time
>> ago in GSOC project far away Martin Dobias got much of the ground work
>> in place but the delta between his branch and master is huge now)
> As you mention, a large part of the work is the data provider refactoring
> (implementing the iterator pattern for every provider).
> On the other hand, it is a task that can be parallelized. If each
> maintainer of a vector provider could implement that for his provider(s),
> that would make the whole process much easier. I'm available to change the
> WFS provider.
> What do others think?
> Regards,
> Marco
> Am 11.07.2012 13:26, schrieb Tim Sutton:
> Hi All
>> Marco and I have been discussing version 2.0 and wanted to bring the
>> discussion onto the list. In particular we are interested in:
>> - When is a reasonable date to aim for the release?
>> - What features will be part of 2.0?
>> - What things are we going to clean away for the release?
>> Here are a list of the possible things that could go into 2.0 that we
>> came up with:
>> - QgsGeometry Refactor to support arcs, measures, 3d geometries and
>> geometry collections (Marco is working on this though unless he is
>> funded to work on it it is unlikely to happen for 2.0)
>> - Raster refactor to use new renderer architecture, native WCS
>> support, pipelines, 'save as' support and more (this work is being
>> funded by the World Bank and will be available in master over the next
>> 3 months)
>> - GSOC project for symbology UI redesign / improvements (how is this
>> work going?)
>> - GSOC project for on the fly feature generalization (also how is this
>> going)
>> - Addition of Sextante into QGIS as a standard plugin (assuming that
>> sits well with Victor)
>> What else do we miss from the list? Are any others out there actively
>> working on features / funding features that we should be aware of?
>> In terms of decrufting, it would be good to remove all the duplicated
>> items:
>> - twin labelling systems
>> - unified add layer dialogs
>> - twin symbology systems
>> - about 15 ways to generate hillshades
>> - too many toolbars / icons by default
>> - remove all deprecated calls from the API
>> Are there any other things that folks would like to add to the
>> discussion for the roadmap for version 2.0?
>> Regards
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.**ch <marco.hugentobler at sourcepole.ch>
> http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
|\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
http://twitter.com/GeoTux2
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120711/36f35812/attachment-0001.html>
