[Qgis-developer] Overview frame in composer
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Fri Jul 13 08:46:03 PDT 2012
Hi John
It is a bug (the feature is still fresh). The list does not get updated
when you add new composer maps.
But it already works if you add the overview map second, since the list
gets populated with the composer maps that are already there.
Regards,
Marco
Am 13.07.2012 17:33, schrieb John C. Tull:
> Hi Marco,
> I don't know if this is a bug or a lack of understanding on this new feature. On a map composer item, I want to add the overview frame. I can select an overview style, but the "Overview frame" drop-down menu only has the "none" option.
> Is there something I need to do to provide an overview choice in that drop-down, or is it possible that the list is not being populated on my OS X system and it is a bug?
> Let me know what I can do to help debug if it is the latter.
> Cheers,
> John
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
