[Qgis-developer] Overview frame in composer
John C. Tull
jctull at gmail.com
Fri Jul 13 08:49:11 PDT 2012
Thanks, Marco. Do you want a bug filed?
On Jul 13, 2012, at 8:46 AM, Marco Hugentobler wrote:
> Hi John
> It is a bug (the feature is still fresh). The list does not get updated when you add new composer maps.
> But it already works if you add the overview map second, since the list gets populated with the composer maps that are already there.
> Regards,
> Marco
> Am 13.07.2012 17:33, schrieb John C. Tull:
>> Hi Marco,
>> I don't know if this is a bug or a lack of understanding on this new feature. On a map composer item, I want to add the overview frame. I can select an overview style, but the "Overview frame" drop-down menu only has the "none" option.
>> Is there something I need to do to provide an overview choice in that drop-down, or is it possible that the list is not being populated on my OS X system and it is a bug?
>> Let me know what I can do to help debug if it is the latter.
>> Cheers,
>> John
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-developer mailing list
