[Qgis-developer] Overview frame in composer
Nathan Woodrow
madmanwoo at gmail.com
Fri Jul 13 08:58:49 PDT 2012
You have to have two map frames on your composer. On the the second one
you select it to be a overview map of the first one.
The UI might need some better naming to explain this better.
- Nathan
Sent from some fancy phone looking thingo
Sent: 14/07/2012 1:33 AM
To: qgis-developer
Subject: [Qgis-developer] Overview frame in composer
Hi Marco,
I don't know if this is a bug or a lack of understanding on this new
feature. On a map composer item, I want to add the overview frame. I
can select an overview style, but the "Overview frame" drop-down menu
only has the "none" option.
Is there something I need to do to provide an overview choice in that
drop-down, or is it possible that the list is not being populated on
my OS X system and it is a bug?
Let me know what I can do to help debug if it is the latter.
Cheers,
John
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
