[Qgis-developer] QgisApp::getThemePixmap() should be in QgsApplication instead?
Etienne Tourigny
etourigny.dev at gmail.com
Mon Jul 16 10:24:21 PDT 2012
On Mon, Jul 16, 2012 at 2:12 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Mon, Jul 16, 2012 at 12:06 AM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> Hi all,
>> I think that QgisApp::getThemePixmap() and getThemeIcon() should be
>> in QgsApplication so that other modules can access it without
>> requiring qgisapp, can I add it there and deprecate the one in
>> QgisApp?
> I think so. For example QgsDataItem::getThemePixmap (copy of
> QgisApp::getThemePixmap) exists only because QgisApp::getThemePixmap
> is not available in core.
my thoughts exactly
> Do you want to keep QgisApp::getThemePixmap in 2.0 as deprecated or do
> you want to deprecate it for a while and remove before 2.0 release?
I would mark it as deprecated it for a time, but remove it entirely
from qgisapp before 2.0 is released.
> General question, is it 2.0 going to have deprecated methods? It
> should not, I believe.
I guess there should not be, but you might want to keep some methods
for backwards-compat, depending on the case.
> Radim
>> Etienne
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
