[Qgis-developer] Side by side install on Ubuntu.
Jeremy Palmer
JPalmer at linz.govt.nz
Tue Jul 17 15:25:37 PDT 2012
Hi Tim,
Yes I tried that. Didn't make any difference to the issues below :(
Cheers,
Jeremy
> -----Original Message-----
> From: Tim Sutton [mailto:lists at linfiniti.com]
> Sent: Wednesday, 18 July 2012 7:19 a.m.
> To: Jeremy Palmer
> Cc: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Side by side install on Ubuntu.
> Hi Jeremy
> On Tue, Jul 17, 2012 at 7:35 PM, Jeremy Palmer <JPalmer at linz.govt.nz> wrote:
> > Hi All,
> > I'm running QGIS 1.8 from installed package on Ubuntu 11.04, as well as trying to
> build and run dev master from a custom installed directory e.g /home/user/dev/qgis-
> install. Version 1.8 seems to run well and I can compile and install the master version.
> However running master (directly calling the qgis binary) causes me issues in a few
> cases:
> > 1/ Fatal: ASSERT: "myResult == 0" in file /home/jpalmer/Dev/qgis/Quantum-
> GIS/src/app/qgsoptions.cpp, line 999. I read that this is due to other versions of the
> qgis core lib being present i.e 1.8 http://lists.osgeo.org/pipermail/qgis-
> developer/2012-February/018375.html
> > 2/ Some python plugins do not load. e.g Couldn't load plugin cadtools due an error
> when calling its classFactory(). Or pgversion: NameError: name 'localePath' is not
> defined
> > 3/ Plugin installer does not see any of my installed plugins and won't let me
> download and install new plugins.
> Have you tried setting LD_LIBRARY_PATH to e.g.
> /home/user/dev/qgis-install/lib before launching master?
> export LD_LIBRARY_PATH=/home/user/dev/qgis-install/lib
> /home/user/dev/qgis-install/bin/qgis &
> Regards
> Tim
> > Is there some sort of environment setup or qgis runtime config I have forgotten to
> do to make this stuff work?
> > Cheers,
> > Jeremy
> > This message contains information, which is confidential and may be subject to
> legal privilege. If you are not the intended recipient, you must not peruse, use,
> disseminate, distribute or copy this message. If you have received this message in
> error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and
> destroy the original message. LINZ accepts no responsibility for changes to this email,
> or for any attachments, after its transmission from LINZ. Thank You.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
