[Qgis-developer] Side by side install on Ubuntu.
Tim Sutton
lists at linfiniti.com
Tue Jul 17 12:19:11 PDT 2012
Hi Jeremy
On Tue, Jul 17, 2012 at 7:35 PM, Jeremy Palmer <JPalmer at linz.govt.nz> wrote:
> Hi All,
> I'm running QGIS 1.8 from installed package on Ubuntu 11.04, as well as trying to build and run dev master from a custom installed directory e.g /home/user/dev/qgis-install. Version 1.8 seems to run well and I can compile and install the master version. However running master (directly calling the qgis binary) causes me issues in a few cases:
> 1/ Fatal: ASSERT: "myResult == 0" in file /home/jpalmer/Dev/qgis/Quantum-GIS/src/app/qgsoptions.cpp, line 999. I read that this is due to other versions of the qgis core lib being present i.e 1.8 http://lists.osgeo.org/pipermail/qgis-developer/2012-February/018375.html
> 2/ Some python plugins do not load. e.g Couldn't load plugin cadtools due an error when calling its classFactory(). Or pgversion: NameError: name 'localePath' is not defined
> 3/ Plugin installer does not see any of my installed plugins and won't let me download and install new plugins.
Have you tried setting LD_LIBRARY_PATH to e.g.
/home/user/dev/qgis-install/lib before launching master?
export LD_LIBRARY_PATH=/home/user/dev/qgis-install/lib
/home/user/dev/qgis-install/bin/qgis &
Regards
Tim
> Is there some sort of environment setup or qgis runtime config I have forgotten to do to make this stuff work?
> Cheers,
> Jeremy
> This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
