[Qgis-developer] Announcing raster-pipes-2 branch for testing
Tim Sutton
lists at linfiniti.com
Fri Jul 20 12:49:52 PDT 2012
Hi
On Fri, Jul 20, 2012 at 5:46 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> On Fri, Jul 20, 2012 at 6:10 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
>> On Fri, Jul 20, 2012 at 12:26 AM, Etienne Tourigny
>>> Yes - I was also thinking about being able to define defaults for
>>> saving rasters (default format, default compression + options per
>>> format, tiles) which would be application-wide.
>>> And this reusable widget could be pre-populated with these options -
>>> and used in core as well as python plugins. You would create an
>>> instance of this widget, given a raster layer, and then be able to
>>> save it.
>>> I would see this as an expandable component inside each of the
>>> gdaltools dialogs.
>> Please keep in mind that other options have to be added to the dialog:
>> * user defined null values - initially will be filled with layer
>> transparency values with 100% transparency
>> * output CRS
>> Should we use tabs?
> I think we could refine that when all parts are there, but it does
> make sense. I would like to eventually have a standalone widget for
> the options, so it could be reused (e.g. in the GDAL tab in the user
> prefs). In this case it would be grafted to the main save dialog.
IMHO using tabs would be a bad idea as it would limit where we can use
it - if we want to embed the widget in another widget we could have a
situation of tabs in tabs which is a HIG no-no. Also have a look at
Guiseppe's dialogs in the gdal tools they provide a simple table for
the Key value pairs. One thing that would be really nice is to have
some default profiles:
- options for maximum read performance regardless of disk space
- options for minumum file size regardless of performance
- options for 'middle of the road' between the above two
Regards
Tim
>> I have granted you write access, please work directly in raster-pipes-2.
> thanks
> Etienne
>> Radim
>>> Etienne
>>> On Thu, Jul 19, 2012 at 7:21 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>>> Hi
>>>> On Fri, Jul 20, 2012 at 12:19 AM, Etienne Tourigny
>>>>> On Thu, Jul 19, 2012 at 4:09 PM, Marco Hugentobler
>>>>> <marco.hugentobler at sourcepole.ch> wrote:
>>>>>> Hi Etienne
>>>>>> Thanks for the feedback, very much appreciated. I've fixed these issues in
>>>>>> raster-pipes-2 branch now.
>>>>>> There are still a few things missing in raster saving:
>>>>>> - write colortable to output dataset
>>>>>> - format specific options (e.g. compression)
>>>>>> - dynamic populating of the format combo box (currently hardcoded to
>>>>>> geotiff)
>>>>>> - progress indication for tile based saving and possibility to cancel
>>>>> It just occurred to me that it would be a great thing to implement
>>>>> this as a widget+class in QgisGui, so that it could be used elsewhere
>>>>> (e.g. gdaltools, sextante).
>>>> You mean as a reusable widget like the crs selector? Yes that would be great!
>>>> Regards
>>>> Tim
>>>>> Any way I can help?
>>>>>> Regards,
>>>>>> Marco
>>>>>> On 18.07.2012 21:12, Etienne Tourigny wrote:
>>>>>>> Noticed a few issues with the save dialog
>>>>>>> 1) "format" drop-down is empty
>>>>>>> 2) cannot select a new file
>>>>>>> 3) segfault when saving to an existing file
>>>>>>> 4) It would be nice to have that action in the legend contextual menu,
>>>>>>> like for vector layers.
>>>>>>> regards,
>>>>>>> Etienne
>>>>>>> On Wed, Jul 18, 2012 at 3:59 PM, Etienne Tourigny
>>>>>>>> That's great news!
>>>>>>>> Concerning raster saving - will there be a mechanism for compressing
>>>>>>>> files?
>>>>>>>> It would be great if default compression schemes could be chosen for
>>>>>>>> different file types, and an option at save time - sort of like image
>>>>>>>> editors.
>>>>>>>> I had trouble building it with external spatialite, could only get it
>>>>>>>> to compile with cmake -DWITH_INTERNAL_SPATIALITE=TRUE - does this
>>>>>>>> require a special version of spatialite?
>>>>>>>> regards,
>>>>>>>> Etienne
>>>>>>>> On Wed, Jul 18, 2012 at 12:13 PM, Marco Hugentobler
>>>>>>>>> Hi devs
>>>>>>>>> I'd like to announce the branch 'raster-pipes-2' in Radims repository
>>>>>>>>> https://github.com/blazek/Quantum-GIS for testing.
>>>>>>>>> Radim did a great job in refactoring the process of reading / resampling
>>>>>>>>> reprojecting / displaying / modifying raster layers. Every step is now a
>>>>>>>>> subclass of QgsRasterInterface, with the advantage that several steps
>>>>>>>>> can be
>>>>>>>>> chained in a QgsRasterPipe. Like that, the raster functionality is
>>>>>>>>> nicely
>>>>>>>>> separated into different classes and it is easy to add/remove elements
>>>>>>>>> in
>>>>>>>>> the pipe. The iteration over the raster parts is controlled by
>>>>>>>>> QgsRasterIterator (because for high-resolution prints or analysis on
>>>>>>>>> large
>>>>>>>>> datasets, it is impossible to keep everything in memory at once).
>>>>>>>>> Please report any issue you find in the branch to the developer mailing
>>>>>>>>> list.
>>>>>>>>> Besides the changes in code architecture, there is also a new feature in
>>>>>>>>> the
>>>>>>>>> raster-pipes-2 branch. It is now possible to write through
>>>>>>>>> QgsRasterDataProvider (currently only supported by the gdal provider).
>>>>>>>>> There
>>>>>>>>> is a 'save as...' function also for rasters now (though it is not 100%
>>>>>>>>> complete at the moment). There is the option to save a raster in one
>>>>>>>>> file or
>>>>>>>>> in tiles (the tiles are then saved in one directory and vrt / pyramides
>>>>>>>>> are
>>>>>>>>> automatically created. Very usefull for saving the contents of a WMS
>>>>>>>>> layer).
>>>>>>>>> Regards,
>>>>>>>>> Marco
>>>>>>>>> Dr. Marco Hugentobler
>>>>>>>>> Sourcepole - Linux & Open Source Solutions
>>>>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>>>>> _______________________________________________
>>>>>>>>> Qgis-developer mailing list
>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>>>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>>>> Please do not email me off-list with technical
>>>> support questions. Using the lists will gain
>>>> more exposure for your issues and the knowledge
>>>> surrounding your issue will be shared with all.
>>>> Visit http://linfiniti.com to find out about:
>>>> * QGIS programming and support services
>>>> * Mapserver and PostGIS based hosting plans
>>>> * FOSS Consulting Services
>>>> Skype: timlinux
>>>> Irc: timlinux on #qgis at freenode.net
Skype: timlinux
